satdown Posted October 29, 2016 Posted October 29, 2016 Just upgraded to 5.6.4. Under settings/options/input/mouse I have always been able to change the mouse wheel to do "channel plus/minus", this no longer works properly with 5.6.4. The channel only changes when enter is pressed on the keyboard. So previously I could change the channel easily just using the mouse, now I have to use both mouse and keyboard. Is there a fix that can make it work the way it used to? Quote
Tjod Posted October 29, 2016 Posted October 29, 2016 Options > TV/Radio >> disable Browse in MiniEPG Quote
