jirim100 Posted November 15, 2016 Posted November 15, 2016 Small bug - file version of DVBVservice.exe is still 1.33.2.0.
Hansrh Posted November 15, 2016 Posted November 15, 2016 Trying to download latest version of RS but my username/password is not accepted - first time this ever happened to me after all these years ??
Tjod Posted November 15, 2016 Posted November 15, 2016 Not a bug, only the svcoptions.exe has been changed. All others files aren't changed. Therefore only this file and the setup where newly generated.
Tjod Posted November 15, 2016 Posted November 15, 2016 There where no changes in the members section. Unless you shared files from the members section or your username and password. There should be no difference to download this version.
Hansrh Posted November 15, 2016 Posted November 15, 2016 There where no changes in the members section. Unless you shared files from the members section or your username and password. There should be no difference to download this version. Problem solved - it was Internet Download Manager that caused it.
