artfarm Posted December 25, 2004 Posted December 25, 2004 Have had no christmas dinner and been at it for over 12 hours. I have no signal although I have a meter saying over 70% Have error message saying EAccessViolation raised by instance frmMain of class TfrmMain at 02C93240:Zugriffsverletzung bei Adresse )2C93240 in Modul 'NeAudio.ax' Lesen von Adresse 00000004 Any help as I do not know where to begin. Not going to bed till I see TV>>>>> Not looking at hooking to Internet just yet..... Quote
Hartwig Posted December 25, 2004 Posted December 25, 2004 The Problem is Nero. Unregister "Nero Digital Audio Decoder" using the Radlight Fltermanager: http://www.DVBViewer.com/forum/index.php?a...e=post&id=17820 Quote
Klausing Posted December 25, 2004 Posted December 25, 2004 Its simply and fast to find a solution for this! Often discussed here in the board. Use Radlight Filtermanager and unregister NeAudio.ax. cheers Steffen Quote
artfarm Posted December 25, 2004 Author Posted December 25, 2004 (edited) Only this was done. Unless nero has another filter and I have missed it. I used Filter manager to unregister it. 25/12/2004 20:57:16 Unregistered: C:\Program Files\Common Files\Ahead\DSFilter\NeAudioEnc.ax Nero Audio Encoder Nero Mpeg Audio Encoder Okay so found lots of nero stuff 25/12/2004 22:05:42 Unregistered: C:\Program Files\Common Files\Ahead\DSFilter\NeAudio.ax Nero Digital Audio Decoder Still.... What about satellite signal. RED RED and more RED......... Edited December 25, 2004 by artfarm Quote
Klausing Posted December 25, 2004 Posted December 25, 2004 NeAudio.ax have nothing to do with the satellite signal !!!! This is only problem for showing picture. Reception is an other problem. Made a channelscan an say us which channels your system found. Quote
artfarm Posted December 25, 2004 Author Posted December 25, 2004 I have no signal. Icon in the bottom right corner is red. It should be green. Just as if no satellite disc was installed. Only it is. I have a sat finder meter and is showing strong signal. I know it should show something on computer. I have got this for christmas and have installed it. Is it possible to have a faulty PC Card??????? New today. neaudio.ax problem has gone but still without signal.. Help please someone...... Quote
Klausing Posted December 25, 2004 Posted December 25, 2004 Made a channelscan an say us which channels your system found. Quote
artfarm Posted December 25, 2004 Author Posted December 25, 2004 (edited) Channels already listed. But when I scan nothing is found. Responder finds and picks up nothing. I loaded a different program earlier that said signal was 13 % this program DVBViewer says 0% which is why I think it is either settings or PC CARD. Do I have to configure first to get a signal???? Edited December 25, 2004 by artfarm Quote
Hartwig Posted December 25, 2004 Posted December 25, 2004 With which program have you done the channel scan. Some people made it with Setup4PC (you should remove this program from autostart). You must do it with the DVBViewer. Quote
artfarm Posted December 25, 2004 Author Posted December 25, 2004 (edited) I have scanned with both. Right now I am actually scaning with both. Which one should I use. You say I will try............ I still say it is the hardware. I do not see how it can pick up channels from scan with NO SIGNAL....... Edited December 25, 2004 by artfarm Quote
Hartwig Posted December 25, 2004 Posted December 25, 2004 You should remove setup4pc from autostart and shutdown this application. Then try a channelscan via DVBViewer. otherwise describe your sattelite system. Do you have a multiswitch or do you use diseqc?? How old is your LNB?? Quote
artfarm Posted December 25, 2004 Author Posted December 25, 2004 After restart a new error message appeared. Cannot set tuner status (wrong settings) error.... well that is something to go by. Still no christmas pudding. Quote
NameIt Posted December 28, 2004 Posted December 28, 2004 Hi you are saying you get no signal? Please check your connections from your PC up to your dish and at least the correct direction of your dish too. HTH NameIt Quote
Klausing Posted December 28, 2004 Posted December 28, 2004 i believe you never got a signal. delete all channels in channellist. You can delete simply the whole satellite. After this perform a channelscan with DVBViewer and tell us which station the viewer found. You wrote you had 13% signal. Thats not enough. BTW you dont wrote anything about your hardeware, software, your dish etc..... Quote
