BASAAM Posted December 30, 2016 Posted December 30, 2016 Here is a AVS+ decoder that found in china forum , due to some profit reason , the author said would not provide a full version decoder to us . We hope developer can use this Semi-finished Decoder to made a new version DVBViewer can supprot AVS+ Video . Thank you. Note: This is not a simple LAVSplitter , it has been modified and add AVS+ Support in it Quote
BASAAM Posted December 30, 2016 Author Posted December 30, 2016 (edited) this is a AVS+ Player that Support TS File made by the same author who made speical LAV. it is a full version but without sound , I hope developer can use it in DVBViewer. Edited December 30, 2016 by BASAAM Quote
BASAAM Posted December 30, 2016 Author Posted December 30, 2016 (edited) DRA Format is a new sound format of china digtal tv , now many software can't not handdle it ,and that's decoder provide by a chinese author found in china forum. I hope it can be add to DVBViewer , when we use it to receive digtal tv sigtal in china. Sorry the file is limited Edited December 30, 2016 by BASAAM Quote
BASAAM Posted December 30, 2016 Author Posted December 30, 2016 remember this decoder must add to MPC-HC 32BIT, Now many Device including Android using 32bit to decoder AVS+ Quote
BASAAM Posted December 30, 2016 Author Posted December 30, 2016 I try to withdrew some useful thing from it. But I Fail to do it. Can DVBViewer Using this exe to provide Pictue when it play AVS+ Video Quote
BASAAM Posted December 30, 2016 Author Posted December 30, 2016 And the video i test which is record by DVBViewer in China Shandong Province by using TS format can be play well. Should I provide A Video Example to Engineer ? I can not upload more than 1mb file Quote
Tjod Posted December 30, 2016 Posted December 30, 2016 Don't open multiple topics for one problem! For a chance to get it working in the DVBViewer you would need a DirectShow Filter version of the Codec. https://msdn.microsoft.com/en-us/library/windows/desktop/dd375464(v=vs.85).aspx So the "AVS+ Player" thing is useless for a connection with the DVBViewer. And where is the Source Code for the modified LAV Filter version? LAV Filters is publicist under the GPL. Which mean if you give a other person access to a changed version you are bound by contract to provide the exact source code from which every one can build exact the version you distributed. I will delete the modified LAV Filter version and you can post it again if you are able to provide the source code. If not don't post it again. The best solution would be to send the necessary changes as pull request to the LAVFilters (or FFmpeg) repository to get it integrated in the official version. https://github.com/Nevcairiel/LAVFilters https://ffmpeg.org/developer.html#Contributing And over all, we are at the same point as in 2015: http://www.DVBViewer.tv/forum/topic/52122-support-for-avs-video-codec/ Quote
spachti Posted December 30, 2016 Posted December 30, 2016 (edited) Didn't we have the same thing about a year ago? Edit: Sorry Tjod, saw your link too late. Edited December 30, 2016 by spachti Quote
BASAAM Posted December 31, 2016 Author Posted December 31, 2016 (edited) Don't open multiple topics for one problem! For a chance to get it working in the DVBViewer you would need a DirectShow Filter version of the Codec. https://msdn.microsoft.com/en-us/library/windows/desktop/dd375464(v=vs.85).aspx So the "AVS+ Player" thing is useless for a connection with the DVBViewer. And where is the Source Code for the modified LAV Filter version? LAV Filters is publicist under the GPL. Which mean if you give a other person access to a changed version you are bound by contract to provide the exact source code from which every one can build exact the version you distributed. I will delete the modified LAV Filter version and you can post it again if you are able to provide the source code. If not don't post it again. The best solution would be to send the necessary changes as pull request to the LAVFilters (or FFmpeg) repository to get it integrated in the official version. https://github.com/Nevcairiel/LAVFilters https://ffmpeg.org/developer.html#Contributing And over all, we are at the same point as in 2015: http://www.DVBViewer.tv/forum/topic/52122-support-for-avs-video-codec/ Sorry , I made a mistake . you need AVS+ source code , I have found in http://www.avs.org.cn/index.asp and it comes up in 2016 August , I repost it to you , Hope it would help you . AVS+ Software Example Source Code.ZIP Edited December 31, 2016 by BASAAM Quote
BASAAM Posted December 31, 2016 Author Posted December 31, 2016 Don't open multiple topics for one problem! For a chance to get it working in the DVBViewer you would need a DirectShow Filter version of the Codec. https://msdn.microsoft.com/en-us/library/windows/desktop/dd375464(v=vs.85).aspx So the "AVS+ Player" thing is useless for a connection with the DVBViewer. And where is the Source Code for the modified LAV Filter version? LAV Filters is publicist under the GPL. Which mean if you give a other person access to a changed version you are bound by contract to provide the exact source code from which every one can build exact the version you distributed. I will delete the modified LAV Filter version and you can post it again if you are able to provide the source code. If not don't post it again. The best solution would be to send the necessary changes as pull request to the LAVFilters (or FFmpeg) repository to get it integrated in the official version. https://github.com/Nevcairiel/LAVFilters https://ffmpeg.org/developer.html#Contributing And over all, we are at the same point as in 2015: http://www.DVBViewer.tv/forum/topic/52122-support-for-avs-video-codec/ is it the new file are useful ? Or i need to send another to you , need translate the README.TXT into English ? Quote
BASAAM Posted December 31, 2016 Author Posted December 31, 2016 here’s old one , the first source code may be the new AVS2 that support 4K , and this old one is AVS1(AVSPlus) support HD AVS1 Software Example Source Code.zip Quote
