Scan single transponder
hse
Hello, I updated to the latest version and it seems i can no longer scan a transponder, In the 4.x versions I could just type in the transponder and scan it. I don't want to scan all transponder as that would be a massive waste of time when adding a feed or new channel. Is there someway to just scan a single transponder or do I need to run a old version.
Edited by hse
Click the question mark tool button for context sensitive help.
  • 1 year later...
I have the same problem. I can't enter the frequency I want to scan. That frequency isn't in the transponder list so I can't "navigate" to it using the combo-box on the right. I don't want to mess with the configuration by editing  ini files. I just want to scan the frequency. I used to be able to do that.
The ""context sensitive help" opens a document that is many pages long doesn't seem to have the answer. What am I missing?
Simply add the frequency in the transponderlist before you start searchin' ;-)
Select transponders you want to search in the boxes located at the right hand side :
