FFmpeg with NVenc for Online Streaming
NightStorm1000
I recently got DVBViewer and set the Recording Server up on my Home Media Server.
This isnt a very Powerfull PC and the Transcoding to Watch stuff in the Browser almost kills my Poor Machine.
But I have an NVIDIA Card inside the PC to use with Hardware Accelerated De- and Encoding.
I also got a self build Version of ffmpeg with the Nvidia Stuff enabled.
But i think the Recording Service has to tell ffmpeg to use that encoder wich would be the "-c:v h264_nvenc" Paramenter.
Is there a way to set this for the Streaming?
See RS installation folder (where DVBVservice.exe is), config sub-directory, ffmpegprefs.ini and iphoneprefs.ini (the latter for Apple HLS). You can modify the command strings. The variable parts in curly brackets like {infile} are filled in by the RS before it launches FFmpeg.
Please note that a new RS version may replace ffmpegprefs.ini and iphoneprefs.ini by updated files.
Ah. I see. Great!
Will test that out as soon as I can. If this works out this would be amazing
