Residentcl Posted January 12, 2017 Posted January 12, 2017 When you double click on the name of the folder, it is not possible to change the name. 1 Quote
Griga Posted January 12, 2017 Posted January 12, 2017 Here it works. Please note that it must be a slow double click. Quote
Griga Posted January 12, 2017 Posted January 12, 2017 That's normal Windows behaviour. Maybe you can change the mouse settings in the control panel. 1 Quote
blasgl Posted January 12, 2017 Posted January 12, 2017 That´s not a double click and has nothing to do with the mouse settings. That is a select (one click) and then change (one click), the same as with the Windows Explorer when you want to rename a file or a folder Quote
