mty Posted December 27, 2002 Posted December 27, 2002 the output file from recording, is m2v and mp2. i try with many tools, aspciely with Tmpg. and all report about Illegaly mpg structure, or fail in end of multiplex, or convert. how i can enjoy from recording, and able to convert edit, and procuce regular mpg1,mpg2 files? (i see that this file not contain information about duration of mov. in same whatch tools, i can see, but the Player can not figure out the duration!) Quote
Klausing Posted December 27, 2002 Posted December 27, 2002 Create with DVD2AVI a project and load this as an videofile in Tmpenc and it will work Quote
mty Posted December 29, 2002 Author Posted December 29, 2002 Thank you about answering. I try it and I find out: *No have a way to join audio and video in DVD2AVI. That mean, (That I cannot cut the Clip in this Step). *I don’t success to make AVI file with no compression. The program fail Immediately, or not do anything (I have a large free space). Therefore, my steps to get a regular Mpg file, is: *convert m2v file to Divx Avi file. *load the output file to TMpg project, and join the mp2 audio file if you want to convert to Divx, take the output Mpg file and go back to Divx. By vitualdub (for example). And if you have many pieces of clip. Go for each, throw out all Procedure. And after build your result into one file. That what you mean in your answer? or maybe I miss something? Anyway, if you know another easy whey, to convert directly the Video and audio to regular Mpg2/1 format, (or Divx) in aspect ratio to fit full screen. And with option to mark out the desirable section, before art of Convert start. Please tell me. I have very experience with TerraTec TV card. It is so easily to capture directly to regular avi file. I don’t understand, why TecnoSat not provide us also easy ways. It is possible to add to DVBViewer ability to record directly to regular mpg file? Thank you a lot Mty Quote
Klausing Posted December 29, 2002 Posted December 29, 2002 I think terratec is analog tv? There is realy a big difference to DVB. The problem is, that every tv station use an other standard for streaming! MPG2 is not the same MPG2 on an other tv station. If you only want to make a simple MPGfile for looking in PowerDVD or WinDVD you can use XMuxer from Moonlight. m2v+mp2=mpg If you want to make a DivX than use DVD2Avi to create the moviepart. Than encode mp2 to mp3 (with Beesweet). NOw you must only muxe both files and you have a great DivX. For an MPG you make a projekt with DVD2Avi. Load this project in TMPenc as video source and the mp2 as audio source. Than you can make what ever you want with TMPenc. The best for all this is, if you have only one stream and splitt it after encoding. If you have the new fullversion you can record as an PVAstream. With this its fantastic to cut or splitt or add the film. PVA Cut and PVAStrumento are great tools for this. And they very fast !!! Steffen Quote
Faber Posted January 1, 2003 Posted January 1, 2003 the output file from recording, is m2v and mp2. i try with many tools, aspciely with Tmpg. and all report about Illegaly mpg structure, or fail in end of multiplex, or convert. Try this: DVBFix Greetings. Quote
