How can I start DVBV if RecSrv server is off
Przemek211
Hello, how can I start DVBViewer if my connection to server is lost and DVBViewer keeps showing load message "Loading Service Channel List"? I believe I don't need to manually delete settings directory.
The start should only take a bit longer (depending on time-outs around 30 sec. or up to 60 sec. is WOL is selected) if the RS is not available.
And the setting is stored in configuration folder\setup.xml
<section name="Service">
<entry name="Enabled">1</entry>
To disable the RS support in DVBViewer change the 1 to a 0 with a text editor e.g. Notepad++
  • Like 1
Thank you, it was 120 sec. which is why i thought it waits endlessly.
Then I assume you had increased the WOL time-out.
