mdio Posted February 6, 2017 Posted February 6, 2017 (edited) Hello all, I've been using my old Skystar HD PCI on Windows 7 32bit, but add too reinstall windows and did it with Windows 10 x64 I have the skystart installed and detected in Windows, run the Setup of DVBViewer Pro, insert the key and when I start it it says [removed] What am I doing wrong?? Thank you in advance. Edited February 6, 2017 by Tjod Quote
Tjod Posted February 6, 2017 Posted February 6, 2017 § 13 Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes. Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not. Remove all Plugins which aren't from this forum here or the members section. That shoud fix the problem. Quote
mdio Posted February 6, 2017 Author Posted February 6, 2017 I was trying to use the old configuration, did a real clean installation everything went fine. thanks. Quote
