DVB subtitles
hvk
I can see either TV image or DVB subtitles with black background - not both at the same time. Could it be that I have some setting wrong or is this a "feature".
Harri
without your settings and needed information --> no solution
Guest hackbart
dvb subtitles are working, but right now only inside the proversion (>2.3 Beta).
Christian
Sorry, here is some more info:
DVBViewer V2.3 (beta)
newOSD plug-in
DVBViewer.log:
27.12.2004 22:26:38 EAccessViolation raised by instance Object8 of class TSkinButton at 0048CE80:Zugriffsverletzung bei Adresse 0048CE80 in Modul 'DVBViewer.exe'. Lesen von Adresse 0000005C
27.12.2004 22:26:40 EAccessViolation raised by instance Object8 of class TSkinButton at 0048CE80:Zugriffsverletzung bei Adresse 0048CE80 in Modul 'DVBViewer.exe'. Lesen von Adresse 0000005C
28.12.2004 17:06:35 EAccessViolation raised by instance EditHex of class TEdit at 00564342:Zugriffsverletzung bei Adresse 00564342 in Modul 'DVBViewer.exe'. Lesen von Adresse 00000000
Setup.ini
Edited by Hartwig
Guest hackbart
try to disable the osd thing.
By the way DVB Subtitles seems now work fine in the new osd wip version.
Christian
I have two machines: on my laptop DVB subtitles work fine, but the other machine (Compaq Deskpro with Windows XP SP2, with Riva TNT2) I can see subtitles with black background (whole screen).
Harri
Riva TNT2
I'm not sure this one supports overlay.
Bye, Oliver
Guest hackbart
maybe you should enable the VMR instead?
Christian
