ripped DVD on HD
linusalba
Hi, is it possible to view a ripped DVD that is in a directory?
I've a dir called DVD where I have some ripped DVD in some dir.
How can I watch these DVD using DVBViewer? Now I'm using PowerDVD for this?
Bye, Marco B)
Simply drag the IFO file of the DVD into the DVBViewer Window.
Really simple B), I'll try soon. thanks, Marco :)
Edited by linusalba
I've tried but It doesn't work for me. If I drag video_ts.ifo I don't see any DVD menu, I don't see anything. If I drag a .vob file I can watch a prt of the movie.
I use DVBViewer 2.3b.
Bye, Marco
Guest hackbart
the problem might be the DVD Navigator from Microsoft. In the new version you will have a Daemon Tool Mount Routine which offers you mount and playback of dvd images.
Christian
Guest Lars_MQ
And it will play ripped DVDs on HD automagically when you navigate with the OSD to the directory with the rip (of course only if it detects the right (DVD) dir-structure :) )
