avoidz Posted March 30, 2017 Posted March 30, 2017 (edited) Hi, I just found an old DTV tuner in my collection; wondered if it's supported by DVBViewer. When I run DVBV and 'Scan Devices', nothing shows up. (Pinnacle) PCTV USB stick (70e) I believe it's from around 2006. Thanks! Edited March 30, 2017 by avoidz Quote
Griga Posted March 30, 2017 Posted March 30, 2017 He can't if the stick doesn't show up in the device list. Looks like a driver problem. Maybe it is not suitable for Windows 7. Quote
avoidz Posted March 30, 2017 Author Posted March 30, 2017 26 minutes ago, Griga said: He can't if the stick doesn't show up in the device list. Looks like a driver problem. Maybe it is not suitable for Windows 7. Windows detected and installed a driver for the stick. I'll try a driver from the PCTV support site and see if it makes any difference. Quote
avoidz Posted March 30, 2017 Author Posted March 30, 2017 (edited) Yep, a different driver worked with the detection. The old stick doesn't seem to pick up any channels though; that's OK, just wondered if it still worked. I'll keep using my ASUS U3000 which seems to still work alright. Cheers! Edited March 30, 2017 by avoidz Quote
