e123enitan Posted April 4, 2017 Posted April 4, 2017 How do I configure two tuners of the 4 to work simultaneously, I have two (3&4) of the turners connected, If i set turner 3 to do not use, and 4 to normal every channel works fine, same goes for if I set 4 do not use and 3 normal, channel works but when set 3 & 4 tuners to normal and try to watch channels in diff frequencies, first client channel would work on one client, but on another client it would freeze the first client channel or caused it to stop while the second client will play. I am not sure where in the settings I have missed the configuration, can someone assist. Cheers! support.zip Quote
Tjod Posted April 4, 2017 Posted April 4, 2017 Disable the RTSP device in the RS options. If you run a different Sat>IP server you may enable that later, if the server is ruing all the time. The RS expects the server linked via RTSP devices to al the time available. Quote
Tjod Posted April 4, 2017 Posted April 4, 2017 And is the second Client not connected via LAN? There are connection attempt from the internet to the RS web interface. Zitat TDVBWebserver InternetAllowed 199.x.x.x access from other nets forbidden, aborted You need to allow internet access to the RS web interface if you need it. But you should never allow access to other RS ports, it is really insecure. If you need it use a VPN between the remote device an router or PC. And you can tray two tuner by ruining a recording and live TV or PiP (run the RS Wizard while two tuners are enabled in the RS and then select via right click a channel for picture in picture in the DVBViewer) Quote
e123enitan Posted April 5, 2017 Author Posted April 5, 2017 22 hours ago, Tjod said: Disable the RTSP device in the RS options. If you run a different Sat>IP server you may enable that later, if the server is ruing all the time. The RS expects the server linked via RTSP devices to al the time available. OK, let me give the approach a try and I shall get back to you. Thanks Quote
e123enitan Posted April 6, 2017 Author Posted April 6, 2017 (edited) 8 hours ago, e123enitan said: OK, let me give the approach a try and I shall get back to you. Thanks HI Tjod, I have just follow your instruction as recon, so I thought, yet I'm still having the same issue. Thanks again! support.zip Edited April 6, 2017 by e123enitan Quote
e123enitan Posted April 7, 2017 Author Posted April 7, 2017 Can someone help!, i am in dead zone here, I can get two tuner or to working simultaneously, when I switch a channel from a client, the other client would freeze, I would expect that since I have more than tuners, the second client request should default to the next ideal tuner, then there shouldn't be an issue, but it appear that this not the case. Pls advice what setting I need to configure to this issue resolved. support.zip Thanks Quote
Tjod Posted April 7, 2017 Posted April 7, 2017 I don't see a problem in the settings. And don't have a idea what the problem is. Is the extra power connector on the TBS 6985 connected to the power supply? Quote
e123enitan Posted April 7, 2017 Author Posted April 7, 2017 17 minutes ago, Tjod said: I don't see a problem in the settings. And don't have a idea what the problem is. Sorry if i don't make my self clearer enough, My tv card has four turners , two activated to normal, while two is set to do not use. I have two clients, expect that each client should be able to access any of tuners, regardless of which of the frequency the channels is located. what I am experiencing, is once any one of the client is tuned to a channel which works fine, the second client couldn't tune to a channel So that is my concern, why can't both client be able to turn separately, Is the extra power connector on the TBS 6985 connected to the power supply? sorry, I don't understand what this meant? However, each turner works independently, while both tuners 3 and 4 are connect, meaning they can not function together to two clients. if I set tuner 3 to "do not use", tuner 4 to "normal" any of the client can tune to channel with tuner 4, both can not connect simultaneously if I set tuner 4 to "do not use", tuner 3 to "normal" any of the client can tune to channel with tuner 3, both can not connect simultaneously I hope this helps Thanks for your supports Quote
e123enitan Posted April 11, 2017 Author Posted April 11, 2017 Sorry I haven't resolve this issue, I have two questions? First question, is how could one determine which tuner a particular channel is using, say i have 4 tuners all the 4's are are receiving CNN channel, so if a client is watching CNN channel, how could I determine which of the turner is being used? Secondly, I used TransEdit to scan channel for the 4 tuners which seems fine, but how could tell which channel is assigned to a particular tuner? Thanks Quote
Derrick Posted April 11, 2017 Posted April 11, 2017 It's determined by the order of the devices in the hardware.xml. Quote
e123enitan Posted April 11, 2017 Author Posted April 11, 2017 2 hours ago, Derrick said: It's determined by the order of the devices in the hardware.xml. Thanks, I thought so myself but I wasn't 100% certain, in that case why is that when one client is already using the first available tuner i.e. 1 turner, then the second client couldn't watch a channel on a diff frequency when the second, third and fourth tuners are available. I have been battling this issue for weeks with not success, it appears that the second client request is send to the first turner, coz when the second client request a channel, it default to first tuner which caused it the first client channel to freeze out, "I am scratching my head to bleed" . I am kind of thing that the hardware config may have been set to "do not use " permanently, therefore, not respecting any future changes in the GUI hardware setting either to "normal or Do not use". Could someone point me to where in the hardware config, how to determine if the turner is set to permanent "Do not use", if that doesn't proved to be the issue, then I can start looking elsewhere I mean either the Disqec or LNB units, just guessing, if I need to look beyond DVB Thanks Quote
e123enitan Posted April 11, 2017 Author Posted April 11, 2017 I am kind of thinking this is where issue lies in the settings of Shared LNB, coz it reflects my settings Shared LNB The "Shared LNB" is only available for DVB-S devices (satellite). It can only be activated if at least two DVB-S devices (or a dual-DVB-S) are present. Enable this setting only for devices which are connected via a two-way distributor to one wire leading to the LNB. If you don't know what this means: Don't touch this setting. This kind of configuration includes some restrictions on the tuning, if both devices are in use: You can only receive channels simultaneously if their polarization, frequency band and DiSEqC settings do match. If the option is enabled for the devices, the DVBViewer considers the restrictions by not allowing a channel selection or recording which would affect a ongoing recording. Quote
