GruberMa Posted April 16, 2017 Posted April 16, 2017 Since the upgrade to DVBViewer 6.0.0.0 the Cursor up and down keys switch channels, just as the add and subtract keys do. They no longer allow to surf through the OSD EPG without actually changing the channel video stream. The key configuration is correct, so I think this is a DVBViewer internal causing this issue. Resetting the key bindings to default values does not help, too. Please advise how to solve this problem and let me know if you need further information. Regards, GruberMa support.zip Quote
Marc32 Posted April 16, 2017 Posted April 16, 2017 try options/ TV/Radio / check "Im MiniEPG blättern" (dont know in english, maybe something like "surf in MiniEPG) 2 Quote
GruberMa Posted April 16, 2017 Author Posted April 16, 2017 That's it, thank you! I can't say though if this setting was changed during the upgrade or if I did it myself Quote
