Kodi no epg
DELLAS
Hello
Iam very happy with new DVBViewer 6.0 and dms 2 but the problem i cant receive epg from vu+ iptv on kodi when using DVBViewer addon
2 hours ago, Tjod said:
Do you have EPG in the DVBViewer Pro?
Yes
Open http://127.0.0.1:8089/api/epg.html?lvl=2 in a web browser (it may take some time) do you get a XML error there if not, everything on the DMS site is OK and the Kodi Add-on needs support for EPG for streaming channels. Because it is not possible to use the normal EPG-ID schema there (most channels would get the same ID there.
ok, ihave this
This page contains the following errors:
error on line 118478 at column 199: Encoding error
Below is a rendering of the page up to the first error.
28 minutes ago, DELLAS said:
ok, ihave this
The problem is same with DVBViewer controller android app
Then there are things in the EPG which are not allowed in XML.
You cold save the page an open it e.g. with Notepad++ and try to locate line 118478 to see what went wrong there.
Or remove every thing around this line and post a text file with line 118478 and may be 2-3 above and below it here.
[stereo] [chi]</description></descriptions></programme><programme start="20170421210000" stop="20170421224700" channel="562954315895241"><eventid>29606</eventid><charset>255</charset><titles><title>天天向丼/title></titles><descriptions><description>天天向不
[16:9]
Nouveau document texte.txt
Edited by DELLAS
Is the EPG collected by the DMS or imported via Xepg?
The Problem seams to be the /title> which should be </title> but the question is what causes it.
By dms
