majstang Posted May 4, 2017 Posted May 4, 2017 Hello! I have been searching the scripting lounge after an easy way to get EPGNow (Time and Title) and EPGNext (Time and Title) for other channels besides the current tuned one. But these methods does only apply for the current channel as it seems. It is somewhere there things gets complicated. Would have been a dreamscenario if passing a channel name or channelID would be enough to the EPGNow and EPGNext and get that Now and next show info. I suspect I need fetch the whole GetAsArray and start calculating from there, right? Some AHK: iDVBViewer := ComObjActive("DVBViewerServer.DVBViewer") EPGNow_Time := iDVBViewer.EPGManager.EPGNow.Time EPGNow_Title := iDVBViewer.EPGManager.EPGNow.Title EPGNext_Time := iDVBViewer.EPGManager.EPGNext.Time EPGNext_Title := iDVBViewer.EPGManager.EPGNext.Title ;msgbox % "Channel= " title "`n" EPGNow_Time . " " . EPGNow_Title . " `n " . EPGNext_Time " " EPGNext_Title " " Quote
Marc32 Posted May 5, 2017 Posted May 5, 2017 (edited) hi, thats not so complicated. unfortunately all i can do is some vbscript. '___________________________________________________________ Set DVBViewer = GetObject(, "DVBViewerServer.DVBViewer")channelnumber = 2 'number of your wanted channelepgcid = DVBViewer.channelmanager(channelnumber).EPGChannelIDSuD = DVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.SIDTuD = DVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.TransportStreamIDepgnow = DVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Titleepgnext = DVBViewer.epgmanager.Get(SuD,TuD,0,0).item(1).Titlestarttime = DVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Timeendtime = DVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Endtimeduration = DVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Durationshowinfo = DVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).DescriptionMsgBox epgnowMsgBox epgnextmsgbox starttimemsgbox endtimeMsgBox durationMsgBox showinfo '______________________________________________________________ you have to pass the channelnumber this time, because getbychannelname is buggy atm. griga knows about it and will fix it (hopefully next release). anyway, the channelnumber is as good as the channelname, i think. hope, this will help you a lil bit marc Edited May 5, 2017 by Marc32 Quote
majstang Posted May 5, 2017 Author Posted May 5, 2017 (edited) Hello Marc! Mighty thanks Hmm...it seems as if Im having some EPG trouble (XEPG imported xmltv). This method returns the wrong EPG entry from the past: 2017-05-03 23:20:00 Blaaaa 2017-05-04 00:50:00 Blaaaaha I may go back to DVBV.5, RS and XEPG .6 to see if the EPG changes of late has something to do with it. iDVBViewer := ComObjActive("DVBViewerServer.DVBViewer") channelnumber := 0 ; number of your wanted channel epgcid := iDVBViewer.channelmanager(channelnumber).EPGChannelID SuD := iDVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.SID TuD := iDVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.TransportStreamID epgnow := iDVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Title epgnext := iDVBViewer.epgmanager.Get(SuD,TuD,0,0).item(1).Title starttime := iDVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Time endtime := iDVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Endtime duration := iDVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Duration showinfo := iDVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Description msgbox % starttime . " " . epgnow . "`n" . endtime " " epgnext " " Edited May 5, 2017 by majstang Quote
Marc32 Posted May 5, 2017 Posted May 5, 2017 (edited) what happens if you specify the time? pls try this for epgnow. epgnow = DVBViewer.epgmanager.Get(SuD,TuD,now,now).item(0).Title and remember you have to change item(0) to item(1) or item(2) or ......... for entries in the future. Edited May 5, 2017 by Marc32 Quote
majstang Posted May 5, 2017 Author Posted May 5, 2017 (edited) Im not sure which time format Get requires "now" does not work by the way. The AHK equivalent is a_now which returns the current local time in YYYYMMDDHH24MISS format. Using that string in the GET call gives error. Edited May 5, 2017 by majstang Quote
Marc32 Posted May 5, 2017 Posted May 5, 2017 (edited) hmm, now works for me:) it returns the right epgentry ahh, pls try without " " Edited May 5, 2017 by Marc32 Quote
nuts Posted May 5, 2017 Posted May 5, 2017 I think "Get" requires the delphi "TDateTime" format. I am using this functions (autoit) for Tdate und Ttime (TDateTime = Tdate + Ttime): Func _Time_to_Ttime($stime) ; nuts (www.autoit.de) ; ; $stime = HH:MM:SS ; return = TDate conform flootingpoint number (i.e. starttime to add a timer) ; @error = 1 => no valid time input If StringRegExp($stime, '\A([0-1][0-9]|[2][0-3])\:[0-5][0-9]\:[0-5][0-9]\z') Then Local $asplit = StringSplit($stime, ":") Return $asplit[1] / 24 + $asplit[2] / 1440 + $asplit[3] / 86400 Else Return SetError(1, 0, 0) EndIf EndFunc ;==>_Time_to_Ttime Func _Date_to_Tdate($sdate) ; nuts (www.autoit.de) ; ; $sdate = YYYY/MM/DD ; return = TDate conform flootingpoint number (i.e. date to add a timer) ; @error = 1 => no valid date input If _DateIsValid($sdate) Then Local $asplit = StringSplit($sdate, "/") Local $iDays = _DateToDayValue($asplit[1], $asplit[2], $asplit[3]) $iDays -= 2415018.5 Return $iDays Else Return SetError(1, 0, 0) EndIf EndFunc ;==>_Date_to_Tdate Quote
majstang Posted May 5, 2017 Author Posted May 5, 2017 Great, that was what I needed Thanks nuts! Im sure I will get this working now. Quote
majstang Posted May 5, 2017 Author Posted May 5, 2017 For VBScript I had to do it like this, which works: channelnumber = 0 'number of your wanted channel epgcid = iDVBViewer.channelmanager(channelnumber).EPGChannelID SuD = iDVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.SID TuD = iDVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.TransportStreamID epgnow = iDVBViewer.epgmanager.Get(SuD,TuD,now,now).item(0).Title epgnext = iDVBViewer.epgmanager.Get(SuD,TuD,now,endtime).item(1).Title starttime = iDVBViewer.epgmanager.Get(SuD,TuD,now,now).item(0).Time endtime = iDVBViewer.epgmanager.Get(SuD,TuD,now,endtime).item(0).Endtime duration = iDVBViewer.epgmanager.Get(SuD,TuD,now,now).item(0).Duration showinfo = iDVBViewer.epgmanager.Get(SuD,TuD,now,now).item(0).Description MsgBox epgnow MsgBox epgnext msgbox starttime msgbox endtime MsgBox duration MsgBox showinfo Now, let see if this can be done with AutoHotkey Quote
majstang Posted May 5, 2017 Author Posted May 5, 2017 Hi nuts! Hmm, I cant get the exact value the Tdatetime is requiring with your code nuts! The now calculations isnt even close, 12hrs off into the future. With a little manual tweaking I can come as close as 3hrs future time. This was tricky to say the least, especially not knowing the details of what the COM interface is requiring. Can you elaborate if somethings is off or check for mistakes? Have tried pretty much everything I could think of, to no avail. #NoEnv ;SetFormat, Float,0.0 FormatTime, Time, YYYYMMDDHH24MISS, HH:mm:ss FoundPos := RegExMatch(Time, "\A([0-1][0-9]|[2][0-3])\:[0-5][0-9]\:[0-5][0-9]\z", SubPat, 1) asplit := StrSplit(SubPat, ":") Ttime := (asplit[1] / 24) + (asplit[2] / 1440) + (asplit[3] / 86400) ;msgbox % Ttime FormatTime, Date, YYYYMMDDHH24MISS, yyyy/MM/dd split := StrSplit(Date, "/") Tdate := gojulian(split[1], split[2], split[3], 2) ; 1 = returns 5 digits and 2 = returns 7 digits ;msgbox % Tdate Tdate -= 2415018.5 ;msgbox % Tdate nowtime := Tdate + Ttime ;msgbox % nowtime iDVBViewer := ComObjActive("DVBViewerServer.DVBViewer") channelnumber := 0 ; number of your wanted channel epgcid := iDVBViewer.channelmanager(channelnumber).EPGChannelID SuD := iDVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.SID TuD := iDVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.TransportStreamID epgnow := iDVBViewer.epgmanager.Get(SuD,TuD,nowtime,nowtime).item(0).Title ;epgnext := iDVBViewer.epgmanager.Get(SuD,TuD,0,0).item(1).Title ;starttime := iDVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Time ;endtime := iDVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Endtime ;duration := iDVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Duration ;showinfo := iDVBViewer.epgmanager.Get(SuD,TuD,0,0).item(0).Description msgbox % starttime . " " . epgnow . "`n" . endtime " " epgnext " " ;===== converts to julian date 5 digits or 7 digits ======== ;===== y=year, m=month, d=day pd =1 for 5 digits, anything else 7 digits============================== gojulian(y,m,d,pd) { if (m < 3) { m += 12 y-- } jdn:=-678972+d+((153*m-2)//5)+365*y+(y//4)-(y//100)+(y//400) if (pd=1) return , jdn else return, jdn+2400000 } Quote
Griga Posted May 5, 2017 Posted May 5, 2017 http://docs.embarcadero.com/products/rad_studio/delphiAndcpp2009/HelpUpdate2/EN/html/delphivclwin32/System_TDateTime.html Quote
nuts Posted May 5, 2017 Posted May 5, 2017 @majstang: Maybe we can compare our results for 2017/05/05 22:50:50 ? I get: TTime=0.951967592592593 TDate=42860 TDateTime=42860.951967592592593 Quote
majstang Posted May 6, 2017 Author Posted May 6, 2017 (edited) 20 hours ago, nuts said: @majstang: Maybe we can compare our results for 2017/05/05 22:50:50 ? I get: TTime=0.951967592592593 TDate=42860 TDateTime=42860.951967592592593 Hi nuts! Hmm...this was truely some tricky shit. COM with AutoHotkey is torture and I believe its the same with AutoIt (or even worse since you stated AutoIt cant access COM object safearrays) (after this you might even consider switching to AHK). Are you sure your TDateTime calculation method works when retrieving now and next show info using the COM Get function with AutoIt? I think you wrote, but edited away, you were using it for adding timers and for that purpose it may work, but with Get your TDateTime value gets rejected (typematching error) by Com Get every time. I discovered this when I managed to calculate the exact same numbers you did in the quoted sample above and apply the method with system now time. So I had to consult the smart guy (qwerty12) again after mere miserable failures of my own. In notime he did find this solution which works great: TDateTime retrieval with AHK and COM Get now and next show info retrieval: #NoEnv st := SystemTime.Now() DllCall("oleaut32\SystemTimeToVariantTime", "Ptr", st.p, "Double*", oleSt) iDVBViewer := ComObjActive("DVBViewerServer.DVBViewer") channelnumber := 0 ; number of your wanted channel epgcid := iDVBViewer.channelmanager(channelnumber).EPGChannelID SuD := iDVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.SID TuD := iDVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.TransportStreamID epgnow := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,oleSt).item(0).Title epgnext := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0).item(1).Title starttime := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,oleSt).item(0).Time endtime := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0).item(0).Endtime duration := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,oleSt).item(0).Duration showinfo := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,oleSt).item(0).Description msgbox % starttime . " " . epgnow . "`n" . endtime " " epgnext " " msgbox % duration "`n" showinfo ; Written by Lexikos for EnableUIAccess /* SystemTime - Wrapper for Win32 SYSTEMTIME Structure http://msdn.microsoft.com/en-us/library/ms724950 Usage Examples: ; Create structure from string. st := SystemTime.FromString(A_Now) ; Shortcut: st := SystemTime.Now() ; Update values. st.FromString(A_Now) ; Retrieve components. year := st.Year month := st.Month weekday := st.DayOfWeek day := st.Day hour := st.Hour minute := st.Minute second := st.Second ms := st.Milliseconds ; Set or perform math on component. st.Year += 10 ; Create structure to receive output from DllCall. st := new SystemTime DllCall("GetSystemTime", "ptr", st.p) MsgBox % st.ToString() ; Fill external structure. st := SystemTime.FromPointer(externalPointer) st.FromString(A_Now) ; Convert external structure to string. MsgBox % SystemTime.ToString(externalPointer) */ class SystemTime { FromString(str) { if this.p st := this else st := new this if !(p := st.p) return 0 FormatTime wday, %str%, WDay wday -= 1 FormatTime str, %str%, yyyy M '%wday%' d H m s '0' Loop Parse, str, %A_Space% NumPut(A_LoopField, p+(A_Index-1)*2, "ushort") return st } FromPointer(pointer) { return { p: pointer, base: this } ; Does not call __New. } ToString(st = 0) { if !(p := (st ? (IsObject(st) ? st.p : st) : this.p)) return "" VarSetCapacity(s, 28), s := SubStr("000" NumGet(p+0, "ushort"), -3) Loop 6 if A_Index != 2 s .= SubStr("0" NumGet(p+A_Index*2, "ushort"), -1) return s } Now() { return this.FromString(A_Now) } __New() { if !(this.SetCapacity("struct", 16)) || !(this.p := this.GetAddress("struct")) return 0 NumPut(0, NumPut(0, this.p, "int64"), "int64") } __GetSet(name, value="") { static fields := {Year:0, Month:2, DayOfWeek:4, Day:6, Hour:8 , Minute:10, Second:12, Milliseconds:14} if fields.HasKey(name) return value="" ? NumGet( this.p + fields[name], "ushort") : NumPut(value, this.p + fields[name], "ushort") } static __Get := SystemTime.__GetSet static __Set := SystemTime.__GetSet } At last am I finished with the DVBViewer COM interface for a while Quite instructive for me and I hope I did help others as a by-product Edited May 6, 2017 by majstang Quote
nuts Posted May 6, 2017 Posted May 6, 2017 Didnt try my functions with iEPGManager.Get but I can test it (behause I am not sure your dllcall always works when you need a TDateTime format). And yeah this COM stuff is very tricky with AHK or autoit. So its good you have something that is working. I will post the result of my tests here when its done. Quote
majstang Posted May 6, 2017 Author Posted May 6, 2017 8 minutes ago, nuts said: I will post the result of my tests here when its done. Yes, please do...that will be interesting ...and good luck with converting the class to AutoIt Quote
nuts Posted May 8, 2017 Posted May 8, 2017 #include <date.au3> #include <DVBViewer.au3> Global $SID=10301 ;ARD HD Global $TID=1019 ;ARD HD Global $o_dvbviewer=_DVBV_Connect() if @error then MsgBox(0, "Error", "DVBViewer Connect fehlgeschlagen => Exit!") exit endif Global $start=_DateTime_toTdatetime(_NowCalc()) ; Nowcalc() =>Returns the current Date and Time in format YYYY/MM/DD HH:MM:SS for use in date calculations Global $end=_DateTime_toTdatetime(_NowCalc()) ; Nowcalc() =>Returns the current Date and Time in format YYYY/MM/DD HH:MM:SS for use in date calculations Global $o_epgmager_GET=$o_dvbviewer.EPGManager.GET($SID, $TID, $start, $end) Global $o_epgmager_item=$o_epgmager_GET.Item(0) Global $s_epgtitel=$o_epgmager_item.Title MsgBox(0, "EPG Item(0)", "Title="&$s_epgtitel) #cs Func _DateTime_toTdatetime($s_datetime) ; nuts (www.autoit.de) ; ; $s_datetime = YYYY/MM/DD HH:MM:SS ; return = TDateTime conform flootingpoint number (i.e. starttime to add a timer) ; @error = 1 => no valid date input Local $a_split_DateTime = StringSplit($s_datetime, " T") If @error = 1 Then Return SetError(1, 0, 0) Local $ret_date, $ret_time, $ret $ret_date = _Date_to_Tdate($a_split_DateTime[1]) If @error Then Return SetError(1, 0, 0) $ret_time = _Time_to_Ttime($a_split_DateTime[2]) If @error Then Return SetError(1, 0, 0) $ret = $ret_date + $ret_time Return $ret EndFunc ;==>_DateTime_toTdatetime #ce My functions are working just fine for me. We could compare DllCall("oleaut32\SystemTimeToVariantTime", "Ptr", st.p, "Double*", oleSt) vs _DateTime_toTdatetime($s_datetime) if you want to. Quote
majstang Posted May 8, 2017 Author Posted May 8, 2017 3 hours ago, nuts said: My functions are working just fine for me. Im happy it works for ya Although these are completely different functions from those you posted initially 3 hours ago, nuts said: We could compare No, since it is working for both there is no need Quote
nuts Posted May 8, 2017 Posted May 8, 2017 vor 46 Minuten schrieb majstang: Im happy it works for ya Although these are completely different functions from those you posted initially _DateTime_toTdatetime = _Date_to_Tdate + _Time_to_Ttime (+ some string convert+ error handling) Your script is just working for "today" isnt it? Anyway if it works for you I am happy. Quote
majstang Posted May 8, 2017 Author Posted May 8, 2017 1 hour ago, nuts said: _DateTime_toTdatetime = _Date_to_Tdate + _Time_to_Ttime (+ some string convert+ error handling) Your script is just working for "today" isnt it? Anyway if it works for you I am happy. Aha...im really bad at reading autoit...it does look quite different from AHK, with all the dollar signs, @ and stuff No, you can retrieve info for any day in the EPG by using the class FromString: st := SystemTime.FromString(20170509225000) Quote
nuts Posted May 8, 2017 Posted May 8, 2017 Yeah should be working for "today" or any other day, but is it working for a specific time range (i.e. 2017/08/05 20:22 to 2017/08/05 23:00)? Quote
majstang Posted May 8, 2017 Author Posted May 8, 2017 Well, if im understanding this right you only need the TDateTime (starttime) from class the rest is up to how you arrange the COM calls, for example this works to retrieve a longer range of titles: st := SystemTime.FromString(20170509185000) ;st := SystemTime.Now() If (DllCall("oleaut32\SystemTimeToVariantTime", "Ptr", st.p, "Double*", oleSt)) ;MsgBox % "oleSt= " oleSt "`nConverted back to intger= " DateTime_ConvertDelphiTDateTime( oleSt ) iDVBViewer := ComObjActive("DVBViewerServer.DVBViewer") channelnumber := 1 ; number of your wanted channel epgcid := iDVBViewer.channelmanager(channelnumber).EPGChannelID SuD := iDVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.SID TuD := iDVBViewer.channelmanager.GetByEPGChannelID(epgcid).tuner.TransportStreamID epgnow := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,oleSt).item(0).Title epgnext := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0).item(1).Title epgnext2 := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0).item(2).Title epgnext3 := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0).item(3).Title epgnext4 := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0).item(4).Title msgbox % epgnow "`n" epgnext "`n" epgnext2 "`n" epgnext3 "`n" epgnext4 Quote
nuts Posted May 8, 2017 Posted May 8, 2017 (edited) That's what I am trying to say. ^^ With this call: epgnow := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,oleSt).item(0).Title Imho you should just receive 1 Item (item(0)=EPGNow). It's no problem for what you are doing here, but it can cause problems if you need a specific TDateTime (i.e. timers etc.) Edited May 8, 2017 by nuts Quote
nuts Posted May 8, 2017 Posted May 8, 2017 Another thing Lars told me years ago. With this: epgnow := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,oleSt).item(0).Title epgnext := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0).item(1).Title epgnext2 := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0).item(2).Title epgnext3 := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0).item(3).Title epgnext4 := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0).item(4).Title You are getting the whole collection every time. This should work better: o_epgGet := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0) epgnow := o_epgGet.item(0).Title epgnext := o_epgGet.item(1).Title Quote
majstang Posted May 8, 2017 Author Posted May 8, 2017 (edited) 40 minutes ago, nuts said: You are getting the whole collection every time. This should work better: o_epgGet := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,0) epgnow := o_epgGet.item(0).Title epgnext := o_epgGet.item(1).Title Nice Wow, tested Item() with expressions and it actually responds to it, but not fully working with AHK expressions though. Hmm... I wonder how the Delphi expressions might look like. Maybe you could even set a range with those? st := SystemTime.FromString(20170509185000) st1 := SystemTime.FromString(20170509235000) If (DllCall("oleaut32\SystemTimeToVariantTime", "Ptr", st.p, "Double*", oleSt)) If (DllCall("oleaut32\SystemTimeToVariantTime", "Ptr", st1.p, "Double*", range_endtime)) epgnow := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,range_endtime).item(0>1).Title epgnow := iDVBViewer.epgmanager.Get(SuD,TuD,oleSt,range_endtime).item(0<1).Title Edited May 8, 2017 by majstang Quote
majstang Posted May 8, 2017 Author Posted May 8, 2017 55 minutes ago, nuts said: Another thing Lars told me years ago. Yeah, "the King" is sorely missed Quote
nuts Posted May 8, 2017 Posted May 8, 2017 Of course you can set a range if your TDateTime is set up right. That's my point, because I am not sure this DLLCall gives you an accurate result. I will check this tomorrow. P.S. Item(0>1) seems wrong to me. You can get the item count and than loop through all items you want. Quote
nuts Posted May 9, 2017 Posted May 9, 2017 @majstang I checked: DllCall("oleaut32\SystemTimeToVariantTime", "Ptr", st.p, "Double*", oleSt)) And I am getting the same output as: _DateTime_toTdatetime($s_datetime) Seems like I missunderstood the msdn docu for "SystemTimeToVariantTime". Anyway both is working like it should and at least we learnded something. Quote
