COM PlayFile
majstang
Seems to work as long as the files passed to function doesn't contain any Unicode special chars in file name.
; Files with special Unicode chars renders this OSD message = Cannot render Mediafile/Input pin, error: 0x80040216
FileToPlay := "F:\TV\Recording Service\20170429_23-54-01_Kanal 5_Ender’s Game - ★★★★★★★☆☆☆.ts"
FileToPlay := "F:\TV\Recording Service\20170505_19-59-01_Discovery Channel_Gold Rush  Alaska - S01E03 - “Hypothermia”.ts"
; These files play OK
FileToPlay := "F:\TV\Recording Service\20170502_19-29-04_SVT2 HD_Hundra procent bonde - S02E06.ts"
FileToPlay := "F:\Edited Recordings\20170305_01-24-01_TV8_Sea of Love -.ts"
iDVBViewer.PlayFile(FileToPlay)
  • Like 1
I can't see why, because the implementation
procedure TDVBViewer.PlayFile(const Filename: WideString);
begin
  frmMain.LoadMediafile(Filename, rtSettings);
end;
and drag & drop of files into the main window are both using LoadMediaFile. Drag & drop works here with filenames containing Unicode special characters.
P.S. No, there is definitely something wrong because here DVBViewer always uses the LAV Source Filter for playing a dragged & dropped TS file with Unicode special characters. It should be the DVBViewer Filter. Let's see what the debugger reveals...
Gotcha :) Will be fixed in the upcoming bugfix release.
Quote
Change Log DVBViewer Pro 6.0.2
  • Fix: File Playback: File playback with the DVBViewer Filter did not work if the filename contained  characters that were not available in the local character set.
Hmm...surprisingly enough I still cannot play files with special chars through COM.  Cannot render Mediafile/Input pin, error: has changed from 0x80040216 to 0x80004005.
Does it work with drag & drop to the main window?
Here it works with Test_File_★★★★★★★☆☆☆.ts
Yes, that is no problem.
Hmm...this is strange:unsure: Invoking COM with AutoHotkey or VBScript like this brings out the problem.
VBScript:
Set iDVBViewer = GetObject(, "DVBViewerServer.DVBViewer")
iDVBViewer.PlayFile("F:\Edited Recordings\20170305_01-24-01_TV8_Sea of Love -.ts")                   'This works
WScript.Sleep 7000
iDVBViewer.PlayFile("F:\TV\Recording Service\20170512_23-59-02_TV8_Åskhjärta - ★★★★★★★☆☆☆.ts")  'Cannot render Mediafile/Input pin, error:  0x80004005.undeifined error
AHK:
iDVBViewer := ComObjActive("DVBViewerServer.DVBViewer")
iDVBViewer.PlayFile("F:\Edited Recordings\20170305_01-24-01_TV8_Sea of Love -.ts")                  ; This works
Sleep 7000
iDVBViewer.PlayFile("F:\TV\Recording Service\20170512_23-59-02_TV8_Åskhjärta - ★★★★★★★☆☆☆.ts") ; Cannot render Mediafile/Input pin, error:  0x80004005.undeifined error
The funny part is it suddenly works if using the thumbnailed app as a drop target (which is how Im gonna utilize it) and executing the same code as above:
;---Drag and drop for the DVBViewer thumbnail
IDropTargetOnDrop_THUMB(TargetObject, pDataObj, KeyState, X, Y, DropEffect) {
   Global iDVBViewer
   ; Get the dropped files
   IDataObject_GetDroppedFiles(pDataObj, DroppedFiles)
    For Index, File In DroppedFiles
      iDVBViewer.PlayFile(File)
   Return 0
Edited by majstang
Looks like the filename is converted to a one-byte (local) character set in between. DVBViewer doesn't do it (see implementation above - it's WideString = UTF-16 throughout). Seems there is quite a lot happening in the COM & Script background...
Ah, these COM IDispatch interface helper functions which are handling conversions seems to do some funny stuff...throwing "curve-balls" trickier than the next;) Why its not doing that conversion in my last (working) code sample is the question...
Edited by majstang
