Sat>IP Viewer for UWP
Hi!
I wonder will there be version for Windows store?
Side note: I think that link to app store in forum description should be updated:
and Mac
Thanks.
Thanks for the link update I have changed it.
And about a Universal Windows Platform app:
Am 10.10.2016 um 13:56 schrieb hackbart:
The DVBViewer is made in Delphi and unless Embarcadero will add support for UWP it is pretty unlikely :(
It is mostly the same, only DVBViewer and DMS are using Delphi 7 and that will mostly stay this way.
The Sat>IP App uses a more up to date Embarcadero IDE, so if a new version of this will support UWP there is the possibility for a UWP App.
