no video or sound
paulipm
system comprises of asus cubx board , pentium 3 8oomhz processor ,
575 GB Sdram , asus Nvidea V9520videosuite videocard , dual operating system
windows xp 1 and windows ME , I get an B2C2 Mpeg filter error ( can
not locate mpeg 2 video/audio filter) I have reinstalled te DVBViewer using the 4.3.0 version same error comes up , tuner settings are ok and the channe selected is not encoded the broadband over satellite signal is ok and when I try to use channel search it picks up the transponders flashing to green but not the individua
channels, I have got TE DVBViewer installed on both my operating systems and am getting the same error on both , it previously worked ok , don't now why it stopped working on both operatting systems , can anybody advise, I realise this a forum for DVBViewer but before I would consider buying the software I want to see the software that came with the card work properly which is after all a vesion of DVBViewer thanks
install drivers from your CD and it will be run.
