rabbit0x536 Posted July 20, 2017 Posted July 20, 2017 Hi, I was wondering if there was a way to change the transcoding presets to allow for example more bandwidth for audio. Also if it was possible to change codecs. AAC and H.265 would be ideal for low bandwidth situations. Quote
Tjod Posted July 20, 2017 Posted July 20, 2017 You can edit the parameter in the ffmpegprefs.ini (C:\Program Files (x86)\DVBViewer\config). https://ffmpeg.org/ffmpeg-all.html Quote
