Date not corrected when time is changed via offset
HorstFuchs
Hi
I'm not sure if this is already known as I didn't find any similar postings.
I wanted to record a broadcast which started at 00:00 until 01:00. After adding
this from the OSD timeline to the recorder, the offset of 2 mins at beginning and end
changed the recording time from 00:00 to 23:58 and from 01:00 to 01:02. So far so good, but the date wasn't changed to the day before so the recording didn't start.
example:
recording data from timeline
broadcast x 01.01.05 00:00 to 01:00
after adding 2 min offset in recorder
broadcast x 01.01.05 23:58 to 01:02
Is it somehow possible to correct this by checking the time and date when adding the offset ?
Thanks and best regards
Horst
Sorry forgot to tell that I'm using Win XP and the DVBViewer 2.2 Pro version
Guest Lars_MQ
confirmed, that's a stupid little bug in the osdtimeline plugin. I corrected the time but forgot the date. Luckily this only happens in very special cases like yours. Sorry bout the missed recording :)
I'll post a bugfix as soon as possible.
lars
Great, no worries about the missed recording. No problem.
Thanks again
Horst
