bccrew Posted July 31, 2017 Posted July 31, 2017 (edited) Hello all, Currently I have a DUO LNB for TV Vlaanderen reception. The DUO LNB is pointed to the Astra 19.2° satellite. When I use DVBViewer I need to set following DiSECq settings to scan for channels: Pos A/Opt A = 19.2° Pos B/Opt A = 23.5° What will happen if I switch to a Triple LNB Quad? (19.2° - 23.5° - 28.2°) Which DiSECq settings would be advisory if I point the Triple LNB Quad to 23.5°? Yes, I need to move my dish a bit to the left to re-align it, but I want the best reception for 23.5° and the manual of the LNB says it's best to point to this sattelite. Thanks Edited July 31, 2017 by bccrew Quote
Derrick Posted July 31, 2017 Posted July 31, 2017 vor 2 Stunden schrieb bccrew: What will happen if I switch to a Triple LNB Quad? (19.2° - 23.5° - 28.2°) Which DiSECq settings would be advisory if I point the Triple LNB Quad to 23.5°? Yes, I need to move my dish a bit to the left to re-align it, but I want the best reception for 23.5° and the manual of the LNB says it's best to point to this sattelite. Thanks Only 1 combination can be correct. Check the specs. 23.5 has to be the one in the middle and will be probably B/A as before. Then I' d guess 19.2 will also be A/A as before. Check it out. There are not many degrees of freedom Quote
bccrew Posted August 1, 2017 Author Posted August 1, 2017 Ok, then I'm in luck. 23.5° is indeed in the middle. I was afraid I had to start playing with more advanced settings.. Thanks Derrick, greetings Matula Quote
Derrick Posted August 1, 2017 Posted August 1, 2017 If it was not in the middle, Astra had to rearrange it's fleet for you Quote
bccrew Posted August 20, 2017 Author Posted August 20, 2017 To give a little follow-up. For a Triple LNB Quad for TV Vlaanderen or Canal Digitaal the following settings worked for me: 19.2° == Pos A/Opt A 23.5° == Pos B/Opt A 28.2° == Pos A/Opt B Quote
