toyotaauris Posted August 6, 2017 Posted August 6, 2017 DVBViewer 5.6.4 and 6.0.3 do not detect the CI module on tt-budget 3200. The field marked as cam display remains inactive. The hardware settings are set to use internal CI. Free programs are displayed normally. Please suggest a solution to the problem. Regards. Quote
Tjod Posted August 6, 2017 Posted August 6, 2017 Do you have the API DLL installed via "DVBViewer Pro Downloader"? If not run the DVBViewer Pro Downloader and install it and the corresponding runtime library. Quote
toyotaauris Posted August 6, 2017 Author Posted August 6, 2017 I see only CIAPI.dll file - this is the one? Quote
Tjod Posted August 6, 2017 Posted August 6, 2017 No, run the "DVBViewer Pro Downloader" (start menu > DVBViewer) and select "CI/Remote Support for Technotrend cards" Quote
toyotaauris Posted August 6, 2017 Author Posted August 6, 2017 During installation on the hardware tab all options were checked. Quote
toyotaauris Posted August 6, 2017 Author Posted August 6, 2017 I launched "DVBViewer Pro Downloader" and chose "CI / Remote Technotrend Tech Support" but still does not detect the module. Quote
