Luciano Gabotti Posted August 25, 2017 Posted August 25, 2017 hi, i have setup the program and i must tell that was easy and very smart. but when i go to the search channels, i have a menu that it sound strange for me: start 50-7 and 1 to the right finish 858-8 and 60 to the right so, what are these numbers ??? what i must put inside is the complete search channels for Italy dvb-t and t-2 or also only a specify frequency channel that can be: ch 30, freq. 546 mhz or ch 40, freq. 626 mhz...etc.etc.etc. so, i find very strange this search channel inside the menu. can someone explain me if i have made mistake ??? thank very much. Quote
Tjod Posted August 25, 2017 Posted August 25, 2017 The selection what to scan is on the page before "Reception Settings" DVB-T > Transponder Lists. The selected transponder list defines the frequents which are scanned. On the Channel Search page you can only select some entry's from the transponder list. But most of the time "Scan Rage" and default settings for the rest is the right choice. In other words scanning all errantry's from the transponder list. Quote
