Sat>IP Viewer for Android: Channel ordering with LCN
Hi Hackbart,
I'm a customer of the DVBViewer for PC and the SAT>IP Viewer for Android. I like both apps!
However, I found a must-have that the SAT>IP Viewer for Android doesn't implement: The LCN support for ordering the channels.
In my region I receive a more than a hundred of channels via aerial. All these channels are ordered using the LCN.
Futhermore, the "other" app for Android (aka EyeTV SAT>IP now from the Geniantech Group) is ordering the channels using the LCN value by default.
But, the problem with the EyeTV is that it doesn't support HD H.264 channels. So, I prefer your SAT>IP Viewer. But ordering channels with a mobile when it can done automatically it's a pain.
So, please can you add support for LCN?
Thank you!
  • 4 weeks later...
Not planned (yet). I have to rewrite big parts, caused by the fact that the latest Delphi Firemonkey, i use for the mobile apps, has several problems i have to drive around.
  • 1 month later...
On 4/10/2017 at 9:18 PM, hackbart said:
Not planned (yet).
I hope you can add it to the todo list soon.
Thank you!
  • 3 weeks later...
I updated the Android build yesterday, but LCN is not added. Anyhow the performance is a bit better and i plan to increase performance of the channel list next. Right now its going slow if you have more than 1000 channels listed.
  • 2 months later...
Hi Hackbart,
I hope you continue improving the SAT>IP Android Client. You'll include LCN in the roadmap?
Regards!
