DVBViewer Pro 5.6.4.0
Molkio
Has anyone saved a copy of DVDviwer 5.6.4.0?
In members download section I can only download version 5.6.4.1, but I need the 5.6.4.0
Thanks!
Setup EXEs are individually personalized with your user key, if someone gives you his EXE it will not work for you (key error). And there is a risk that the key of the person is banned who gives away his EXE.
Look in your program folder C:\Program Files (x86)\DVBViewer\Setup, the installers should have saved all the setup files you installed here.
For the future: Make backups of all your personalized setup files, there is no way to get them again if they are no longer downloadable in the members section.
  • Thanks 1
ThanKs! I found a copy in my program folder :)
Edited by Molkio
