mitsu Posted October 30, 2017 Posted October 30, 2017 Without any changes anywhere, DVBViewer stopped finding any stations, antenna, cable or satellite. Scan for devices in the settings work fine and finds all three devices I have. Transedit does not work either. I cannot figure out any remedy to this. support.zip Quote
mitsu Posted October 31, 2017 Author Posted October 31, 2017 A little more information about this. I have three devices (antenna, cable and satellite). Every channel just says "No hardware available". This started without any changes to hardware or software or anything else. I was using the system via RDP and without reboot started local use and this happened. Channel scan with DVBViewer or Transedit both say "No hardware". Hardware is working fine. I installed ProgDVB and it works fine. I will next uninstall and re-install DVBViewer. Quote
mitsu Posted October 31, 2017 Author Posted October 31, 2017 (edited) A little more information about this. I have three devices (antenna, cable and satellite). Every channel just says "No hardware available". This started without any changes to hardware or software or anything else. I was using the system via RDP and without reboot started local use and this happened. Channel scan with DVBViewer or Transedit both say "No hardware". Hardware is working fine. I installed ProgDVB and it works fine. I will next uninstall and re-install DVBViewer. Re-installing did not help. (I kept the user data. Maybe there is something wrong in the user data.) Edited October 31, 2017 by mitsu Quote
Griga Posted October 31, 2017 Posted October 31, 2017 I would try to return to a system restore point that was created before it ceased to work. 2 hours ago, mitsu said: Maybe there is something wrong in the user data Quite unlikely. "No hardware available" is no typical symptom of wrong user data. Quote
mitsu Posted October 31, 2017 Author Posted October 31, 2017 Spoiler Unfortunately system restore is disabled. (Is this again a Microsoft Windows 10 improvement.) I have a backup which I will restore if there is no other option available. Any ideas what has happened? Quote
Griga Posted October 31, 2017 Posted October 31, 2017 54 minutes ago, mitsu said: Unfortunately system restore is disabled Usually it is enabled by default. 23 hours ago, mitsu said: Without any changes anywhere, Are you sure that you didn't receive the Creators Update (or any other Windows update) during this time? Because what you describe is a known Creators Update issue: http://www.dvbviewer.tv/forum/topic/59399-no-playback/?do=findComment&comment=462963 Quote
mitsu Posted November 1, 2017 Author Posted November 1, 2017 Yes, I already had the Creators Update and it has been working fine. Problem really looks pretty much as described in the link. Except that ProgDVB worked with the devices and DVBViewer did not. Anyway, I restored the backup and the system is fine again. I also installed the Creators Update and everything is still fine. Strange. Quote
Griga Posted November 1, 2017 Posted November 1, 2017 It's still a mystery why this happens. Several people encountered this issue after a Creators Update (upgrade) installation. In two known cases ProgDVB was still able to use the DVB hardware. So unless proven otherwise we will follow the common (western) practice and assume that it is caused by Russian hackers or even Putin himself 1 Quote
