Babyvancho Posted November 11, 2017 Posted November 11, 2017 Good afternoon, I have a computer as a server with two Skystar HD2 cards. I also have two Raspberry Pi 3 connected to two televisions and I can not see two different channels at the same time unless they have the same frequency. I have tried to program the channels in different groups and associate each group to a card. Thank you very much Quote
Derrick Posted November 11, 2017 Posted November 11, 2017 Do you have 2 independent cables from your LNB or multi switch to your cards? And you must not check "shared LNB" in the hardware section. Quote
Babyvancho Posted December 2, 2017 Author Posted December 2, 2017 Only one cable comes from my LNB because it is a community antenna. I have a duplicator to connect a cable to each card. I can now see two different channels but after a while he stops decoding one of them and stops. I have two 8 clines and the Load Balacer activated but I can not see two channels of different frequencies without blocking one of them after a few minutes. I have tried only one active card at the same time and it does work. please, I need help, I do not know what else it can be. Quote
