Error 404 when direct stream some file using upnp server
leijlo
Hi, I bought some days ago DVBViewer media server, but I'm encountring some problem when I try to stream some video file in DVBViewer pro using the upnp server.
I noticed that when I copy the url using dvbvierpro I get an url like this http://192.168.1.2:8090/upnp/video/video%2Fx-msvideo/AVI/00003.avi?d=4337 that, if I past on my browser i get  an  "404 - not found" error.
The file exsist on my pc , indeed if I presst the button "play in browser "using the web interface, the file works normally, but doens't work if I press the "http single stream" button.
Obviously for the files that are working, pasting the url on the browser for example http://192.168.1.2:8090/upnp/video/video%2Fx-msvideo/AVI/00004.avi?d=5390, the browser begin to download the file.
This doesn't happen to all file present in my catalog, but on less or more 30 files on hundreds I have.
Can anyone help me to solve this issue?
Thanks in advance
Have you already tried to update or rebuild the video database (see web interface -> tasks page)?
yes, I've also tried to share the folder only with 1 file, same result
Please check if the files in question are write-protected. I just saw in the code that the DMS opens the files for shared read/write access, which fails in case of write protection.
I guess the purpose of this  access mode is playback of ongoing recordings that must be opened consistently with the recorder access mode. However, I think it would be better if the DMS would additionally try a read only access mode if shared read/write fails. Or the other way round. ;)
  • Thanks 1
YES!!! The read only flag was checked on those files. Unchecking the flag, I can stram those files normally!
Thanks a lot!
