Customize toolbar don't save
Palomino3000
HI,
when I customize toolbar (vision x icon set),
then every time exit and reload dvbviwer the save was lost!!
How I can save permanetly?
I have the last version of dvbviwer and windows10 64bit and I lunch the program with administrator rights.
thanx for help!!
Here it works.
The configuration is saved in the file setup.xml (see configuration folder) as
<settings>
  <section name="General">
  <entry name="Icons">........</entry>
  <entry name="ToolbarContent">.......</entry>
Please check if you can find it in your setup.xml and if changes are stored there. If not: Does DVBViewer remember other changes in Settings -> Options?
