bogdan1980 Posted January 6, 2018 Posted January 6, 2018 Some logos expand over channel name, guide etc in web interface on ios, android, DVBViewer controller, etc. I tried to grab other logo with smaller dimensions but still the same. Quote
VinoRosso Posted January 6, 2018 Posted January 6, 2018 (edited) This is not true for the DVBViewer Controller App. There is a fixed size for the logos, can you show a screenshot? Edited January 6, 2018 by VinoRosso Quote
bogdan1980 Posted January 7, 2018 Author Posted January 7, 2018 Yes, sorry, DVBViewer controller is working ok, logo is ok. Quote
Griga Posted January 7, 2018 Posted January 7, 2018 Please attach one of the "out of bounds" logos. Quote
Griga Posted January 12, 2018 Posted January 12, 2018 Well, these are 1026 x 234 images. The recommended format is 268 x 200. So why don't you resize them to a reasonable resolution? Anyway, it would be better if the Mobile Web Interface would be able to shrink such monster logos to a fixed size. I'll look after it as soon as I find time for it.... Quote
janee Posted January 12, 2018 Posted January 12, 2018 (edited) vor 1 Stunde schrieb Griga: Anyway, it would be better if the Mobile Web Interface would be able to shrink such monster logos to a fixed size. I'll look after it as soon as I find time for it.... As I can see, the Mobile Webinterface does shink the images to a fix height=60px. <a href="#" style="background-image: url('{logourl}?height=60')" The Problem is here the aspect ratio. You have to resize the image to 268 x 200 or a multiple of it. e.g. if you shrink your image from 1026 X 234 to 263 X 60 , if you shrink the recommended format you get 80 X 60 The width of 80 fits perfect in the webinterface. @Griga: algo needed for image resizing and keeping the aspect ratio Edited January 12, 2018 by janee Quote
Griga Posted January 12, 2018 Posted January 12, 2018 I hoped that you would have a look at it There is a similar problem in the video section of the Mobile Web Interface with widescreen video thumbnails: Quote
