eXtremeDevil Posted January 28, 2018 Posted January 28, 2018 All of a sudden I can't record from IPTV anymore. I also have a DVB-T card that records file. I'm using Recording Server latest version and DVBViewer 6.0.4.0. I add an IPTV device on RS and then use it on DVBV. I can see the channel but when I click on record nothing happens. Can I provide more info to you? Thanks. I attach the support.zip. support.zip
eXtremeDevil Posted January 28, 2018 Author Posted January 28, 2018 Sorry, turned out to be Windows F*king Firewall. I have allow the RS now through it. Does that mean I have an open port now or something? Thanks.
Griga Posted January 28, 2018 Posted January 28, 2018 If a router (not a simple DSL modem) handles your internet connection (the usual case) there is still another firewall protecting you. The only thing that may be dangerous if not done with care is port forwarding in the router that allows clients in the internet to connect to a server in your private home network.
