Griga Posted February 4, 2018 Posted February 4, 2018 (edited) For my own needs (and for not getting confused when changing between DVBViewer GE and Pro) I've created a GEStyle icon set for the DVBViewer Pro main window toolbar. It is now available in the Plugins section of the download area. The icon set provides the "look and feel" of the DVBViewer GE toolbar. Basically it is an extended XPedition icon set with some changed and additional icons. In contrast to the standard VisionX set it only covers a subset of all DVBViewer Pro actions. Feel free to add self-made icons to it, if you want/need to. Please read the DVBViewer Pro 6.0.4 change log for more information or ask here. Requirements: DVBViewer Pro 6.0.4 or later. Installation and Configuration:(1) Copy the GEStyle folder from the ZIP file into Program Files (x86)\DVBViewer\Images\Icons\ (so that there is a GEStyle sub-directory)(2) Restart DVBViewer(3) Right-click the toolbar and click "Customize" to open the Toolbar Editor(4) Select GEStyle as icon set.(5) Click "Default" for setting up the standard GEStyle toolbar or configure manually which icons shall appear in which order(6) Finish with OK Edited February 4, 2018 by Griga Image added Quote
