URL for m3u file and EPG for IPTV Player
Cian
That API is way beyond anything that I have any chance of using. I haven't programmed in decades (that was when C had only just received it's first +!).
This video shows how to enter the URL in Perfect Player, but I would like a URL that points to my DVBViewer Media Server at home. I just don't know if that functionality exists in DVBViewer MS.
Sorry if I'm not being clear - I don't really know how to put it any other way.
Thanks,
C.
There are two versions of the m3u file - a simple file format or an extended 'plus' format that contains grouping information.
The basic format is as follows:
#EXTM3U
#EXTINF:-1,Station Name
http://mymediaserver.web:8089/live/myusername/mypassword/station1.ts
The format of the m3u_plus file is as follows:
#EXTM3U
#EXTINF:-1 tvg-id="Station_name" tvg-name="Station Name" tvg-logo="" group-title="Folder Name",Station Name
I have also seen versions where the stream link has the following format:
http://mymediaserver.web:8089/live/myusername/mypassword/station1.m3u8
EDIT: Doh! Of course I'm being stupid - this is the kind of file that gets imported into DVBViewer for IPTV Streams so you understand the format better than I do. Sorry.
C.
Edited by Cian
It's easy to get a channel list as M3U from the DMS that contains URLs for all channels or a selection of channels. E.g. try
http://127.0.0.1:8089/channels.m3u
in a browser on the PC where the DMS is running. Download the M3U and have a look inside by using a text editor. It contains an URL for each channel, e.g.
#EXTINF:-1,arte HD
http://127.0.0.1:7522/upnp/channelstream/2359890582722586686%7Carte%20HD.ts
Every HTTP client can get the channel list in this way. However, the DMS does not support the tvg tags as shown in your post. Maybe a future extension will provide them...
And what would it be from a remote client with username and password?
Get the "outside" DMS IP address (the one of the network adapter in the server PC) from the DMS Web Interface -> Status Page -> Webserver IPs section:
http://username:password@IP:8089/channels.m3u
That works from the web browser, but not on the IPTV player. Don't know what way the IPTV players pull in the m3u list, but it doesn't like it!
It would have made things a little more convenient, but it's not that important.
Thanks for you time.
C.
