can't load channels kodi addon
mezzy
hi
i notice that i can't load more than 120 channels in Kodi addon
is there a limitation in DMS or loading guide (epg) channels is the problem ?
thanks for reply
i use local stream with KODI-addon an the problem is still here
pvr manager can't load more than 120 channels !!
This is not the KODI forum and if you have problems with that add-on you have to ask around there.
sorry for the inconvenience I thought you were the developer for addon too
