leijlo Posted April 3, 2018 Posted April 3, 2018 Hi, Please help me I'm getting crazy. On my upnp file list, i can see only folder, but all the files have empty names, like there is a permession issue somewhere. Reading the log file I found this 03.04.18 08:12:11.176 TRecordingEngine Exception: Error executing SQL statement. Error [11]: The database disk image is malformed. "Drop table object_details": database disk image is malformed Can be releated with this error? support.zip Quote
Griga Posted April 3, 2018 Posted April 3, 2018 11 minutes ago, leijlo said: Can be releated with this error? Yes. You may need to do the following: Stop the DMS Remove the file svcmediaVideo.db3 from the Database sub-directory of the configuration folder Restart the DMS Go to the Tasks page of the web interface and rebuild the video database. If the audio and photo database are also damaged the same steps must be performed respectively (e.g. remove svcmediaAudio.db3 and rebuild the audio database). 1 Quote
