DVBViewer Video Editor V1.0.0
hackbart
I'm happy to announce the first version of the DVBViewer Video Editor.
You find the official page to the editor here: http://www.DVBViewer.com/en/index.php?page=dve
The trial is limited to 14 days and allows only 3 batch jobs at a time. This should be enough to detect advertisements and cut a video.
Features:
  • 32bit and 64bit builds are available (you need 64bit directshow decoders if you use the 64bit version)
  • support for MPEG-2 -Audio and -Video, AAC, AC-3, H.264, HEVC (UHD)
  • support for TS and MPG containers. It is quite likely that the next version is also able to open and edit other formats, because the code is 95% complete for this ;)
  • Direct3D video rendering for best and fastest possible playback of the video streams. The engine comes with a complete video player
  • support for visual impaired users. All functions can be easily reached via keyboard and/or mouse.
  • customizeable icons (if necessary)
  • batch tool for automated processing via command line
  • optional indexing, in order to make exact cuts
  • no reencoding is required, which means it is extremely fast
  • support for teletext and subtitle streams
  • Spoiler mode. This one might be useful if you don't want to get spoilered while editing a video. The audio is minimized and the video is partially hidden. A nice gimmick some users might like to have
  • Multilingual GUI - at the moment only German, English and Swedish are available, but i hope people will translate the text into their native language later.
One of the questions i probably receive is if there is a way to speed up the loading. By default the application will index every video once you open it. Indexing means that the editor checks the video for I-Frames (which are complete images). This is necessary when it comes to cut the file.
Without indexing the cuts are not that exact. You can disable indexing in the options. An alternative method is to index the file in background. In this case the video is opened immediately and once the indexing is finished, the index will be used.
Christian
PS: Many thanks to our beta testers, especially @Majstang. Without his suggestions the software would be still more rudimentary.
  • Like 2
  • 3 weeks later...
I've updated the 32 and 64 bit installer.
Version 1.0.3.0
  • fixed:Engine:problems while editing certain video files.
  • fixed:Engine:sometimes there where twitches around the cut points
  • added:Engine:if everything fails, ffmpeg is used automatically to cut
  • added:Editor:position in the file is now shown in cut list window
  • added:Editor:save as now shows transcoding file extensions
  • fixed:Editor:While trimming the editor was able to load another video
  • added:Editor:Option to set the best view automatic
  • changed:Editor:Nagscreen is now centered on the active monitor
  • fixed:Editor:Sub windows went to background
  • changed:Editor:File name for saving is now based on the original file name
  • changed:Editor:Initializing the Time line is now done as separate task in background
  • Like 1
Version 1.0.5.0
  • fixed: Engine: problems with AAC LATM streams where solved
  • fixed: Editor: jump one frame back now works again, even if the indexing is disabled
  • fixed: Editor: damaged index files are now detected and deleted
  • Like 1
Version 1.0.6.0
  • fixed:Engine:some mpeg2 streams caused problems
  • fixed:Installer:problems with downloading ffmpeg
  • fixed:Editor:under XP the editor did not worked fine with H264
  • Like 1
  • Thanks 1
Version 1.0.7.0
  • fixed:Installer:https links for ffmpeg
  • fixed:Engine:teletext is included in the alternative muxer
  • Like 1
  • 3 months later...
Version 1.0.8.0
  • fixed:Installer:usage of 7za.dll
  • added:Editor:Joiner Window to combine several recordings into one big file
  • fixed:Editor:Explorer Function to open the editor with a video via open with now works
  • Like 1
  • 7 months later...
Version 1.1.0.0
  • fixed:Editor: some HEVC/AAC ts streams where asynchronous after editing them. This has been fixed.
  • Like 1
  • 2 months later...
Version 1.2.0.0
  • added: Cutter: Parameter %width% and %height% for ffmpeg commands. The parameters provide the correct information of each stream which has to be passed to ffmpeg
  • added: Editor: alternative tool bar mode with rearranged buttons
  • fixed: General: refractoring of the core parts
  • fixed: General: problems with WideString to AnsiString and vice versa conversions
  • added: Installer: updated comskip version
  • changed: Editor: microseconds are now shown on the osd
  • Like 1
