Recording button not active
achterblad
In DVBViewer 2.3 Beta is the recording option not active. Is this a "feature" of the Beta? In the older version (which does not run stable on my system) I can make direct recordings.
Scheduled recording is possible - but sometimes incomfortable ...
I cleaned my system totally (using an older system image) and installed all the packages (Technisat Sky Version, then DVBViewer Pro) a second time. Same result, red button inactive.
achterblad.
there is a file, regfilter.exe, in the DVBViewer directory. Run it once befor you use the viewer. After using an older version, you must do it again.
P.S. If you want to speak german, you can use the german part of the forum :wacko:
