Stream in browser doesn't work any more
uglyned
I used to be able to stream channels and play them in the browser window.
But now - tested in Chrome and Firefox - when I click 'stream in browser' it provides a file - .master.m3u8' that I can either open (in VLC) or save.
I don't get the stream in browser any more.
With the other reported issue it means I can no longer watch any TV through DVBViewer or Media Server!
Edited by uglyned
Bizarrely the only thing that works is to save the 'm3u' file using the 'other player (m3u) button then open that file in DVBViewer.
Most likely HLS is selected as output format. For playing it in the desktop versions of Firefox and Chrome you need to install the Native HLS Add-On (up-to-date Android versions can do without it, as well as Edge unter Windows 10).
Or just switch to WebM as output format.
  • Thanks 1
