Recording to multiple HDDs
philc
This might be a dumb question, i run a media server at home, and record shows for my kids to view off kids channels as well as normal shows in the evening that arent suitable for younger children. Modern motherboards have more than two sata ports to allow multiple high speed HDDs running in situ.
My question is with media server - Its it possible to choose a destination while creating a timer ? - eg Normal show (eg grahame norton) to D:  kids show (eg thunderbirds) to E:
then the kids can have their own library away from more mature content. Found the kids watching content they shouldnt be on plex and wondered if it was possible to seperate.
Thanks
Media Server Options (svcoptions.exe) -> Recorder -> Directories -> Add as many as you need.
You can select the directories as target when creating or editing timers In the DMS Web Interface (timer dialog window > Recording Folder dropdown list). The default setting "Auto" lets the DMS select the target directory automatically according to the DMS Options -> Recorder settings. Make sure that Configuration Page -> Web Interface -> Show timer edit window is switched on.
