Maarten De Rijsal Posted June 5, 2018 Posted June 5, 2018 Hi , when i move main window his lag help me please also after installing lavfilter -> no present directx option i tested k-lite mega codec pack -> lav filter present directx option I do not understand support.zip Quote
Webturtle Posted June 6, 2018 Posted June 6, 2018 Hello, you should download LAV Filters from here: https://github.com/Nevcairiel/LAVFilters/releases. The Installer works for 32- and 64-bit Systems. That means the 32-bit version that is needed by DVBViewer is installed too with the 64-bit version. On my system this LAV works! Many greetings Webturtle Quote
Maarten De Rijsal Posted June 6, 2018 Author Posted June 6, 2018 27 minutes ago, Webturtle said: Hello, you should download LAV Filters from here: https://github.com/Nevcairiel/LAVFilters/releases. The Installer works for 32- and 64-bit Systems. That means the 32-bit version that is needed by DVBViewer is installed too with the 64-bit version. On my system this LAV works! Many greetings Webturtle thanx and for my first question : when i move main window his lag ? Quote
Webturtle Posted June 8, 2018 Posted June 8, 2018 Hello, I'm sorry,I don't what this means. Many greetings Webturtle Quote
