Unable to wake up from suspend after Windows 10 upgrade
Jacob Andersen
After a recent upgrade from Windows 10 1709 to 1803 then my Recording Service has stopped being able to wake up my HTPC when suspending.
Anyone who have had the same problem and a potential solution?
/JSA
Thanks but WOL works. It is when the HTPC is suspending and a timer is set for recording something then it has stopped waking up by it self. this used to work flawlessly.
/JSA
You have a 10 day grace period to revert the update. Its crap anyway and the recommendation is to update several months after the release when the nastiest bugs are fixed. Or if you want to be an early adopter you might as well join the other million testers army they got nowadays.
Edited by majstang
