e123enitan Posted July 2, 2018 Posted July 2, 2018 support.zip Please help, after installing DVB Pro 6., the channel works seems to work fine,and changing channels seems no issue (ie) no lag ) except First, HD channels are smearing with green,/yellow colors on the low part of the screen. and Secondly, when I installed the DM server, connect client through wizard I can't watch any channel, the signal displayed is strong on the bar, which indicate the channel is receiving, but every channel that turned to will not work. Quote
e123enitan Posted July 2, 2018 Author Posted July 2, 2018 (edited) I went to the this file svchardware.xml then change to 2 DiSEqCCount">1</entry for every tuner Edited July 2, 2018 by e123enitan Quote
