alk Posted July 31, 2018 Posted July 31, 2018 Hello there is a way to export the channel list EPG to XML ??? Quote
Delphi Posted July 31, 2018 Posted July 31, 2018 For the DMS (DVBViewer Media Server) there is: XgrabDMS (see my signature). This is in xmltv format. For DVBViewer: EPG window -> Export -> select file type XML. This is NOT in xmltv format. Quote
alk Posted July 31, 2018 Author Posted July 31, 2018 Tank you i will try XgrabDMS to export xmltv, but i was meaning for a link on DMS like i can donwload m3u list ... Quote
Griga Posted July 31, 2018 Posted July 31, 2018 1 hour ago, alk said: but i was meaning for a link on DMS like i can donwload m3u list That's possible by using the DMS API, e.g. with http://127.0.0.1:8089/api/epg.html?lvl=2&download=1 Read more about the API here and here. &download=1 is important because your poor browser may crash if it has to render 20 MB EPG data as xml. However, the output is a proprietary DMS XML format and not compatible with xmltv. Using it requires some programming skills. Quote
alk Posted July 31, 2018 Author Posted July 31, 2018 (edited) Yeah that was i looking for, but if its a DMS XML propietary format its useless :((((( I am trying to pass it to plex with the channel m3u list (using a plex dvr proxy) there are some channels that plex dont recognize. Otherwhise i am trying the XgrabDMS but i get this error "Get error : 404 failed get last error 0" the conection with my DMS its fine but no channels in the XgrabDMS grid. Edited July 31, 2018 by alk Quote
