beeswax Posted August 30, 2018 Posted August 30, 2018 (edited) I almost posted this over on the Kodi forum under the addon section but I think this is an api limitation. If any recording is cut short, or stopped/resumed for some reason, the duration for said recording(s) get reported incorrectly by the api. The api seems to assume all recordings ran their full course and just reports the length of the programme from the EPG e.g. "1h". Example from a recording that was stopped by a sever reboot and then resumed: api/recordings.html: <recording id="4" charset="255" content="160" start="20180830100000" duration="010000"> rec_listnew.html?aktion=rec_listnew: Thu 30/08/2018 10:00 (00:04) The api is reporting 1 hour but the web interface correctly reports 4 minutes. Both have the start time incorrect and just use the EPG start time, is that possible to fix as well? support.zip Edited August 30, 2018 by beeswax Quote
Griga Posted August 30, 2018 Posted August 30, 2018 5 hours ago, beeswax said: The api is reporting 1 hour but the web interface correctly reports 4 minutes. Both have the start time incorrect and just use the EPG start time, is that possible to fix as well? No. /api/recordings.html was designed to report the start time and duration from the associated EPG data / EPG info file... don't ask me why, I don't know. Once an API is introduced it can't be changed anymore for compatibility reasons. The only possibility is to extend it by adding new XML elements/attributes (e.g. "trueduration") or to create a new API, e.g. /api/recordings2.html. Usually players retrieve the true duration by analyzing the file. Network clients can do it as well by reading the beginning and the end of a TS file and checking the time stamps. Quote
