Channel List Lost On Crash.
Hello, this is a bug that has bugged me for a while.
If you do a channel scan, then try view some of the channels. A channel with a weak signal can cause DVBViewer to crash,
When this happens and you reopen DVBViewer the channel list you just scanned is missing. It seems it's only saved when
you cleanly exit the client.
It would be nice if the channel list was auto saved on a scan completing
There is a save tool button in the channel editor (floppy disk icon).
it would disable the reload/undo function after a scan.
