mezzy Posted September 26, 2018 Posted September 26, 2018 hi i've got a problem with my 2 cards I can not use my 2 cards simutaneouslyI do not know if they are compatible because those are 2 different brands or a problem of drivers or the fact that the satellite is powered i made tests but the only thing i found is i must deactive one to have video picture of the second one i need help and advice thanks Quote
mezzy Posted September 26, 2018 Author Posted September 26, 2018 DD S2 cine v6 has octopus bridge Quote
mezzy Posted September 28, 2018 Author Posted September 28, 2018 hi i've got a problem with my 2 cards I can not use my 2 cards simutaneouslyI do not know if they are compatible because those are 2 different brands or a problem of drivers or the fact that the satellite is powered i made tests but the only thing i found is i must deactive one to have video picture of the second one DVBS2 has octopus bridge i need help and advice thanks Quote
Griga Posted September 28, 2018 Posted September 28, 2018 TBS6301 is a HDMI video capture card, isn't it? So it is not related to DVB or satellite reception and is not used in DVBViewer, correct? Quote
mezzy Posted September 30, 2018 Author Posted September 30, 2018 tbs is an acquisition card and works as a satellite map need to scan a transponder (TP12538) for video pictures in transediti done tests and choose 2 different satellite lists as well as different channel groups too but no luck and i have the latest firmware from cine S2 octopus bridge the only way to work is to turn off one card to see the other one in DVBViewerI will inquire with tbs for help too someone got an idea? Quote
