Volume control problem
aydan
Hi there,
I just noticed a huge problem with the DVBV volume control. It seems it controls the OS wave volume. Which is pretty bad, since sometimes you want to turn down the TV sound but listen to something else.
Bye
Aydan
Well, did you select wave as output device? You should only use Directsound output.
Bye, Oliver
I had it set to NVIDIA nForce Audio, which seems to have the same effect. Thanks for the Tip.
nForce Directsound or nForce Wavesound? Which one you set?
Guest Lars_MQ
That's seem the same with nforce chipsets. Only if you choose "default wave out" you get the problems.
lars
