Wikre Posted January 22, 2019 Posted January 22, 2019 Hello, I can't get the joiner to work. I've added a second .ts file to the joiner window, but it won't save a joined file. I've already tried to open the second file in the video editor, as to create a .mlmix file, but this didn't work. The second file is not appearing in the timeline, either, don't know if this is suppose to happen or not. Am I missing something? 32-bit version. Quote
Wikre Posted January 22, 2019 Author Posted January 22, 2019 Turns out I was missing something, but in my defence: it seems a little illogical to me... You have to put both files into the joiner, then click 'convert' and enter a filename. And then nothing seems to happen, except for that it does join the two files in the location you specified. So, for a better user experience: - Either: after one has added files to "joiner...", show them back-to-back on the timeline, and allow the user to work with these file as if it were one large file; - Or: rename the button 'convert' into 'join' (even 'merge'?) and show a pop-up (as happens with indexing and saving). Quote
